Ir para o conteúdo principal
Logitech G400s Mouse Cable Replacement
O que você precisa
  1. Logitech G400s Mouse Cable Replacement, Mouse Cable: passo 1, imagem 1 %32
    • Use a Jimmy to remove the mouse feet.
    • Be careful to remove any film left by the mouse feet as well.
  2. Logitech G400s Mouse Cable Replacement: passo 2, imagem 1 %32
    • Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
  3. Logitech G400s Mouse Cable Replacement: passo 3, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
  4. Logitech G400s Mouse Cable Replacement: passo 4, imagem 1 %32
    • Gently pull the upper shell away from the bottom platform.
  5. Logitech G400s Mouse Cable Replacement: passo 5, imagem 1 %32
    • This is what the G400s will look like when the top shell is taken off.
  6. Logitech G400s Mouse Cable Replacement: passo 6, imagem 1 %32 Logitech G400s Mouse Cable Replacement: passo 6, imagem 2 %32
    • Push the cable into its proper place inside the mouse shell.
Conclusão
Max Evans
Membro desde: 09/28/16
403 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-7, Eyestone Fall 2016 Membro de USF Tampa, Team 16-7, Eyestone Fall 2016
USFT-EYESTONE-F16S16G7
1 Membro
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 47
Duração total: 4,276
