Ir para o conteúdo principal
Logitech G29 Driving Force Red Dial Replacement
O que você precisa
  1. Logitech G29 Driving Force Red Dial Replacement, Red Dial: passo 1, imagem 1 %32 Logitech G29 Driving Force Red Dial Replacement, Red Dial: passo 1, imagem 2 %32 Logitech G29 Driving Force Red Dial Replacement, Red Dial: passo 1, imagem 3 %32
    • Take off the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. The outer diameter of these screws are 8.40mm with a length of 26mm.
    • Once the center cap is off, take the face of the wheel off the stand. Before totally taking off, disconnect the 7 pin white cable running into the base of the wheel and place base aside.
  2. Logitech G29 Driving Force Red Dial Replacement: passo 2, imagem 1 %32
    • Remove wire connecting the PCB to the base of the wheel.
  3. Logitech G29 Driving Force Red Dial Replacement: passo 3, imagem 1 %32 Logitech G29 Driving Force Red Dial Replacement: passo 3, imagem 2 %32
    • Take off the 7 4.32mm diameter 8mm long silver screws holding the PCB to the black housing on the wheel using bit J0.
    • Move the PCB to the side to expose the back side of the red dial. Keep the remaining white cable connected to the secondary PCB.
    • Be careful not to lose the buttons and D-pad because once the PCB was removed they can easily be lost.
  4. Logitech G29 Driving Force Red Dial Replacement: passo 4, imagem 1 %32 Logitech G29 Driving Force Red Dial Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Press in the 3 red tabs located on the inside black housing of the dial. Using the medium sized tweezers, the black center button was pushed out to reveal 3 small black screws.
    • Using the same bit as earlier, bit J00 remove the three 3.32mm diameter 5mm length screws to release the red dial.
Conclusão
Ben varner
Membro desde: 11/08/23
373 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-3, Harley Fall 2023 Membro de IUPUI, Team 1-3, Harley Fall 2023
IUPUI-HARLEY-F23S1G3
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 118
Duração total: 687
