Ir para o conteúdo principal
Logitech G29 Driving Force Pedal Replacement
O que você precisa
  1. Logitech G29 Driving Force Pedal Replacement, Pedal: passo 1, imagem 1 %32
    • Begin by orienting the pedal box onto its underside.
    • Remove the twelve #1 Phillips screws that secure the bottom cover to the pedals.
  2. Logitech G29 Driving Force Pedal Replacement: passo 2, imagem 1 %32
    • Remove the remaining twelve #0 Phillips screws from the bottom cover.
  3. Logitech G29 Driving Force Pedal Replacement: passo 3, imagem 1 %32
    • To remove the pedal, first take out the 2 Allen screws located in the middle of the pedals.
    • You only need to remove the screws out of the pedal that needs fixing. Any others can stay where they are.
  4. Logitech G29 Driving Force Pedal Replacement: passo 4, imagem 1 %32
    • Now that all screws are loose the back plate should be able to be removed revealing the pedals.
  5. Logitech G29 Driving Force Pedal Replacement: passo 5, imagem 1 %32
    • If pedal is unresponsive start by checking the gear mesh.
    • If gear mesh is not connecting check to make sure everything is tight.
    • If gears are stripped or have broken off get replacement gears.
  6. Logitech G29 Driving Force Pedal Replacement: passo 6, imagem 1 %32
    • If gears are fine check the wire connections.
    • If red wires are loose, resolder and make sure the connection is good.
    • If the black ground wire is loose, tighten it up.
    • If none of these fix the problem, source a replacement pedal.
Conclusão
Uma outra pessoa concluiu este guia.
2Comentários do guia
Hola. Tengo un problema en el conexionamiento desde los potenciometros hasta el conector DIM9. ¿Alguien puede pasar Esquema Electrico para poder conexionar los distintos cables en los pins correspondientes?
EckoCharliE72 - Responder
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 77
Últimos 30 dias: 334
Ao todo: 8,728
