Ir para o conteúdo principal
Logitech G1 Optical Mouse Scroll Wheel Replacement
O que você precisa
  1. Logitech G1 Optical Mouse Scroll Wheel Replacement, Scroll Wheel: passo 1, imagem 1 %32
    • Remove one screw at the bottom of the mouse.
  2. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 2, imagem 1 %32 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 2, imagem 2 %32
    • Pull the top of the mouse lid gently to separate it from the rest of the mouse.
    • Potential for device damage: The lid and the body are connected with a wire, so separate them gently.
  3. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 3, imagem 1 %32 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 3, imagem 2 %32
    • Pull the white connector from the circuit board.
    • Be sure the two small holes in the connector are positioned at the top when reassembling.
  4. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 4, imagem 1 %32 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 4, imagem 2 %32
    • Carefully pull the scroll wheel up.
    • The long parts of the spring should be in the southeast and southwest directions when reassembling.
  5. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 5, imagem 1 %32 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 5, imagem 2 %32
    • Carefully remove the two Phillips #0 screws.
  6. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 6, imagem 1 %32 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 6, imagem 2 %32
    • Clean the mouse case, lid, and module with a dry cotton swab or soft brush.
    • Potential for device damage: Do not use water or an iron brush to clean it.
  7. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 7, imagem 1 %32 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 7, imagem 2 %32
    • Place the new scroll wheel into the mouse.
  8. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 8, imagem 1 %32
    • The spring should be inserted into a small groove.
    • The spring can be inserted after combining the mouse body.
Linha de Chegada
wooseok yang
Membro desde: 01/19/21
304 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 24
Duração total: 1,251
