Ir para o conteúdo principal
Logitech G Pro X Superlight Scroll Wheel Replacement
O que você precisa
  1. Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: passo 1, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: passo 1, imagem 2 %32 Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Mouse skates will be damaged during this process. Having a new pair of mouse skates is STRONGLY recommended.
    • Use tweezers to peel off the mouse skates on the underside of the mouse.
  2. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 2, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 2, imagem 2 %32
    • Unscrew the six screws using a 1.6mm Phillips screwdriver on the top and bottom side of the mouse.
  3. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 3, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 3, imagem 2 %32
    • Open the bottom shell with your hands.
    • Use caution, as wires are still intact.
    • The bottom shell should come off easily without applying any force.
  4. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 4, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 4, imagem 2 %32
    • Disconnect the wires and cables in contact with the sensor's motherboard.
    • Pull and shake evenly on the cable to make sure cables are not strained. Avoid pulling heavily.
  5. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 5, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 5, imagem 2 %32
    • Take out the battery located at the back of the mouse.
    • Flipping it upside down helps when removing it.
  6. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 6, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 6, imagem 2 %32
    • Remove four screws at the bottom part of the mouse with a 1.6mm screwdriver.
  7. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 7, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 7, imagem 2 %32
    • Carefully take out the left and right mouse buttons.
  8. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 8, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 8, imagem 2 %32
    • Remove the four screws attached to the scroll wheel.
  9. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 9, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 9, imagem 2 %32
    • Apply pressure and shake evenly to remove the attached cable.
    • The scroll wheel comes off easily without using too much pressure.
    • Insert the new scroll wheel and line up against the sensor.
  10. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 10, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 10, imagem 2 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 10, imagem 3 %32
    • Reattach the cable.
    • Refasten the four screws.
  11. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 11, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 11, imagem 2 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 11, imagem 3 %32
    • Use a pair of tweezers to reinsert the four screws at the bottom half of the mouse and tighten with a screwdriver.
    • Attach the battery back on the bottom half of the mouse.
    • Reattach the two cables.
  12. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 12, imagem 1 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 12, imagem 2 %32 Logitech G Pro X Superlight Scroll Wheel Replacement: passo 12, imagem 3 %32
    • Line up the bottom shell with the top shell and connect them together.
    • Reapply the four screws back onto the mouse.
  13. Logitech G Pro X Superlight Scroll Wheel Replacement: passo 13, imagem 1 %32
    • Put on your new mouse skates.
    • Apply pressure so that they stick to the mouse, leaving no air gap.
Linha de Chegada
Zane
Membro desde: 07/27/23
280 Reputação
Autoria de 1 guia
Equipe
York University, Team M-9, Allen Summer 2023 Membro de York University, Team M-9, Allen Summer 2023
YORK-ALLEN-SU23SMG9
Membros da 2
Autoria de 7 guias
2 comentários
Thanks for publishing this!
Do you replace only plastic part of wheel or plastic wheel + PCB?
Where do you order new wheel?
Andriy Legayev - Responder
https://ausmodshop.com/products/modded-l... pricy, but they have full replacement pcbs with all the parts installed for you so you
Daniel G -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 136
Últimos 7 dias: 848
Últimos 30 dias: 3,299
Duração total: 17,077
