Ir para o conteúdo principal
Logitech Extreme 3D Pro USB Cable Replacement
O que você precisa
  1. Logitech Extreme 3D Pro USB Cable Replacement, Disassembly of the handle: passo 1, imagem 1 %32
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro USB Cable Replacement: passo 2, imagem 1 %32
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro USB Cable Replacement: passo 3, imagem 1 %32 Logitech Extreme 3D Pro USB Cable Replacement: passo 3, imagem 2 %32
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro USB Cable Replacement, Disassembly of the base: passo 4, imagem 1 %32
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro USB Cable Replacement: passo 5, imagem 1 %32 Logitech Extreme 3D Pro USB Cable Replacement: passo 5, imagem 2 %32 Logitech Extreme 3D Pro USB Cable Replacement: passo 5, imagem 3 %32
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro USB Cable Replacement, USB Cable: passo 6, imagem 1 %32 Logitech Extreme 3D Pro USB Cable Replacement, USB Cable: passo 6, imagem 2 %32
    • Carefully pull from the plug head straight up.
    • It may require some force to remove the cable. However be careful not to damage the wires.
Conclusão
Emanuel Canela
Membro desde: 01/25/18
1.297 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S7-G1, Passmore Spring 2018 Membro de USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
Membros da 4
Autoria de 7 guias
6 comentários
What type of replacement cable do I need? Where can I purchase it?
Tom Tidbury - Responder
Along with Tom, I would also like to know where I can get replacement parts for this joystick. I’ve been searching for a while now and can’t seem to find any spare parts for this joystick.
Clayton Noyes - Responder
Savez-vous où l'on peut trouver cette pièce à l’achat ou à la récupération?
Jordan Stéphane Martinez - Responder
Hey! @thetechchild I had a similar issue, couldn't find replacement parts after my cat chewed on the cable.. So I found an alternate solution, I bought some of these cables, some heat shrink tubing, and replaced the cable like this. Now I can detach a male to male USB A cable to the joystick and replace the cheap cable if it ever gets damaged again! Make sure to plug the cables into the pin connector in the exact same way that the original cable was plugged in: Green, White, Red, thin Black, thicker Black (left to right as shown in the images I linked above). I think I could have gotten a JST XH plug to better connect it, but doing the pins directly seems to be working fine for now. I'm not entirely sure if that's the correct plug, but from my research it looks like it.
William McCall - Responder
Sadly same issue, tried all the linked products, looks like the design of the cables have changed. I cant get it to work even with the JST plug. Thanks for giving me a little hope though!
Dylan Brasier (Grim) - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 2,398
