Ir para o conteúdo principal
Logitech Extreme 3D Pro Main Joystick Spring Replacement
O que você precisa
  1. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the handle: passo 1, imagem 1 %32
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 2, imagem 1 %32
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 3, imagem 1 %32 Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 3, imagem 2 %32
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the base: passo 4, imagem 1 %32
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 5, imagem 1 %32 Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 5, imagem 2 %32 Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 5, imagem 3 %32
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: passo 6, imagem 1 %32 Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: passo 6, imagem 2 %32
    • Disconnect the wire from the motherboard.
  7. Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 7, imagem 1 %32 Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 7, imagem 2 %32
    • Remove this plug from the motherboard.
  8. Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 8, imagem 1 %32 Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 8, imagem 2 %32
    • Remove the four 10mm Phillips #1 screws from the joystick base.
  9. Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 9, imagem 1 %32
    • Remove the joystick assembly.
  10. Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 10, imagem 1 %32
    • Remove the white plastic piece on top of the spring.
    • The white plastic will be covered in a lubricant.
  11. Logitech Extreme 3D Pro Main Joystick Spring Replacement: passo 11, imagem 1 %32
    • Remove the Spring
    • The spring will be covered in lubricant.
Conclusão
5 outras pessoas executaram este guia.
Emanuel Canela
Membro desde: 01/25/18
1.297 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S7-G1, Passmore Spring 2018 Membro de USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
Membros da 4
Autoria de 7 guias
6 comentários
um, what kind of spring is that and where/how would I get a replacement?
Swift Foxe - Responder
same question here
Robbert Sprezzatura -
Where can I find a replacement spring?
ande3224@bellsouth.net - Responder
Anyone found a source for replacement springs?
Chandler - Responder
You can cut the top 360 degrees off the spring with a Dremel cutoff tool, that reduces the work require to operate the stick by about half.
Frank Clarke - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 165
Duração total: 11,194
