Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
After extended use certain parts may require cleaning or replacement. This guide will assist you in safely disassembling the top handle portion of the joystick.
O que você precisa
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
6 outras pessoas executaram este guia.
2 comentários
yeah but i got this far before looking at the site, and what i really want to see is how the cotter ring pin is set on the shaft that enables the z-rot instead of locking it down.
if you havent worked it out already, the Z-rot spring needs spread across a little 3/8 inch tab, otherwise it will lock the axis a few degrees off center
