Ir para o conteúdo principal
Logitech Extreme 3D Pro Disassembly of the handle
O que você precisa
  1. Logitech Extreme 3D Pro Disassembly of the handle, Disassembly of the handle: passo 1, imagem 1 %32
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the handle: passo 2, imagem 1 %32
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the handle: passo 3, imagem 1 %32 Logitech Extreme 3D Pro Disassembly of the handle: passo 3, imagem 2 %32
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
Conclusão
6 outras pessoas executaram este guia.
Emanuel Canela
Membro desde: 01/25/18
1.297 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S7-G1, Passmore Spring 2018 Membro de USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
Membros da 4
Autoria de 7 guias
2 comentários
yeah but i got this far before looking at the site, and what i really want to see is how the cotter ring pin is set on the shaft that enables the z-rot instead of locking it down.
erock steady - Responder
if you havent worked it out already, the Z-rot spring needs spread across a little 3/8 inch tab, otherwise it will lock the axis a few degrees off center
cody Werdal -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 35
Duração total: 3,434
