Ir para o conteúdo principal
Logitech Extreme 3D Pro Disassembly of the base
O que você precisa
  1. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the handle: passo 1, imagem 1 %32
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the base: passo 2, imagem 1 %32
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the base: passo 3, imagem 1 %32 Logitech Extreme 3D Pro Disassembly of the base: passo 3, imagem 2 %32
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the base: passo 4, imagem 1 %32
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Disassembly of the base: passo 5, imagem 1 %32 Logitech Extreme 3D Pro Disassembly of the base: passo 5, imagem 2 %32 Logitech Extreme 3D Pro Disassembly of the base: passo 5, imagem 3 %32
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
Conclusão
3 outras pessoas executaram este guia.
Emanuel Canela
Membro desde: 01/25/18
1.297 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S7-G1, Passmore Spring 2018 Membro de USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
Membros da 4
Autoria de 7 guias
Um comentário
And you didn’t even finish the repair. Thanks for nothing. :(
Jesse James - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 64
Duração total: 3,685
