Introdução
After extended use certain parts may require cleaning or replacement. This guide will assist you in safely disassembling the base portion of the joystick. This will require to have to handle already disassembled.
O que você precisa
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
3 outras pessoas executaram este guia.
