Ir para o conteúdo principal
Logitech Dual Action disassembly
O que você precisa
  1. Logitech Dual Action disassembly, Taking out the screws: passo 1, imagem 1 %32
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
  2. Logitech Dual Action disassembly, Opening the controller: passo 2, imagem 1 %32 Logitech Dual Action disassembly, Opening the controller: passo 2, imagem 2 %32 Logitech Dual Action disassembly, Opening the controller: passo 2, imagem 3 %32
    • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
    • Separate the top and bottom casing.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
  3. Logitech Dual Action disassembly, Cleaning the buttons: passo 3, imagem 1 %32
    • Turn the top casing of the controller over to remove all the buttons.
    • Wipe each individual button with a piece of cloth and rubbing alcohol.
Linha de Chegada
10 outras pessoas executaram este guia.
Brian Neuman
Membro desde: 01/20/15
893 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 7-4, Remmell Winter 2015 Membro de USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
Membros da 4
Autoria de 3 guias
Um comentário
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 93
Duração total: 6,183
