Ir para o conteúdo principal
Logitech Dual Action Joystick Replacement
O que você precisa
  1. Logitech Dual Action Joystick Replacement, Taking out the screws: passo 1, imagem 1 %32
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw marked with orange.
  2. Logitech Dual Action Joystick Replacement, Opening the controller: passo 2, imagem 1 %32 Logitech Dual Action Joystick Replacement, Opening the controller: passo 2, imagem 2 %32 Logitech Dual Action Joystick Replacement, Opening the controller: passo 2, imagem 3 %32
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
  3. Logitech Dual Action Joystick Replacement, Replacing the joystick: passo 3, imagem 1 %32 Logitech Dual Action Joystick Replacement, Replacing the joystick: passo 3, imagem 2 %32
    • With the case off, the joysticks can be removed by pulling them upward.
    • To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
    • Make sure that the cut-out side of the joystick is towards the outsides of the device.
Linha de Chegada
14 outras pessoas executaram este guia.
Brian Neuman
Membro desde: 01/20/15
893 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 7-4, Remmell Winter 2015 Membro de USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
Membros da 4
Autoria de 3 guias
5 comentários
Can the Analogue Stick be replaced with the One of XBOX 360 or PS3 Controller
shivam sah - Responder
will the buttons still work if you put it all back?
Atsuku - Responder
When you press the buttons, they don't work, but when you press hard, they only work, and they don't work just by pressing normally?
[deleted] - Responder
Merci pour le site.excusez moi pour le dérangement j'ai ma manette PS2 qui ne fonctionne pas quand je branche ça me dit que c'est pas connecté
Mohamed Abass Sylla - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 38
Últimos 30 dias: 167
Duração total: 9,829
