Ir para o conteúdo principal
Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement
O que você precisa
  1. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Safety precautions: passo 1, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Safety precautions: passo 1, imagem 2 %32
    • Before you begin, ensure that the engine is off and cool to the touch.
  2. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 2, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 2, imagem 2 %32
    • Locate the gas cutoff valve and flip the switch to the left to shut it.
  3. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 3, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 3, imagem 2 %32
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Remove the deflector cable: passo 4, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Remove the deflector cable: passo 4, imagem 2 %32
    • Remove the cotter pin from the clevis.
  5. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 5, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 5, imagem 2 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 5, imagem 3 %32
    • Remove the clevis pin.
  6. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 6, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 6, imagem 2 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 6, imagem 3 %32
    • Slide the ball at the end of the cable through the round opening in the clevis.
    • Remove the clevis from the deflector cable.
  7. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 7, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 7, imagem 2 %32
    • Slide the rubber boot off of the cable housing to the end of the cable.
  8. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 8, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 8, imagem 2 %32
    • Use a 7/16 inch wrench to unscrew the nut securing the cable housing to the bracket.
  9. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 9, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 9, imagem 2 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 9, imagem 3 %32
    • Slide the cable housing out from the deflector lever bracket.
  10. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Remove the master link: passo 10, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Remove the master link: passo 10, imagem 2 %32
    • The next two steps will show you how to remove the master link on the deflector chain.
  11. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 11, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 11, imagem 2 %32
    • Use a pair of pliers to unclip the master link.
    • Remove the master link retaining clip.
  12. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 12, imagem 1 %32
    • Remove the outer plate.
  13. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 13, imagem 1 %32
    • Remove the chain from the end of the deflector cable.
    • Repeat steps 11–13 for the upper master link if necessary.
    • During reassembly, follow steps 11-13 in reverse order to reinstall the master links.
  14. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 14, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 14, imagem 2 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 14, imagem 3 %32
    • Squeeze the tabs on either side of the cable pusher with a pair of pliers and slide it through the bracket.
    • Remove the deflector cable.
  15. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Install the new deflector chain: passo 15, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Install the new deflector chain: passo 15, imagem 2 %32
    • The following steps show how to install a new deflector chain.
    • Note the center link on the deflector chain.
    • Note the middle tooth of the pivot.
    • The deflector knob has been removed for illustrative purposes.
  16. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 16, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 16, imagem 2 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 16, imagem 3 %32
    • Drop the middle link onto the middle tooth of the pivot.
  17. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Adjust the deflector cable: passo 17, imagem 1 %32
    • Lift the deflector so that it is horizontal.
    • Turn the deflector knob clockwise to lock the deflector horizontally in the wide-open position.
  18. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 18, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 18, imagem 2 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 18, imagem 3 %32
    • Slide the cable housing back onto the deflector lever bracket.
  19. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 19, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 19, imagem 2 %32
    • Slide the clevis back on to the deflector cable.
  20. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 20, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 20, imagem 2 %32
    • Insert the clevis pin through the clevis and the deflector adjustment lever.
  21. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 21, imagem 1 %32
    • Move the deflector lever into the open position.
  22. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 22, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 22, imagem 2 %32
    • Use an open-ended wrench to tighten the 7/16 inch bolt until the cable is taught.
  23. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 23, imagem 1 %32
    • Slightly loosen the deflector knob to allow the deflector to move freely.
  24. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 24, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 24, imagem 2 %32
    • Use the lever to open and close the deflector to check that cable is properly adjusted.
    • If the deflector does not fully open, the cable needs to be tightened more:
    • Repeat step 17, then step 22 but give the nut an additional clockwise turn.
    • Repeat steps 23–24.
    • If the deflector does not fully close, the cable needs more slack:
    • Repeat step 17, then step 22 but give the nut an addition counterclockwise turn.
  25. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 25, imagem 1 %32
    • Use an open-ended wrench to tighten the other 7/16 inch bolt on the cable housing until it is snug against the bracket.
  26. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 26, imagem 1 %32 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: passo 26, imagem 2 %32
    • Slide the rubber boot back onto the end of the cable housing.
    • Install the cotter pin onto the clevis pin.
Linha de Chegada
Sam Omiotek
Membro desde: 02/25/19
61.096 Reputação
288 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 476
