Ir para o conteúdo principal
Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement
O que você precisa
  1. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Disconnect the spark plug: passo 1, imagem 1 %32 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Disconnect the spark plug: passo 1, imagem 2 %32
    • Before you begin, make sure the engine is switched off and cool to the touch.
    • Pull the spark plug connector straight off of the spark plug.
  2. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Remove the clutch bracket clamp: passo 2, imagem 1 %32
    • Use a 5/16 inch socket to remove the two nuts securing the clutch bracket clamp.
    • You may need another 5/16 inch wrench to hold the bolt from underneath while you loosen the nut.
  3. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: passo 3, imagem 1 %32
    • Remove the clutch bracket clamp.
  4. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Remove the clutch drum: passo 4, imagem 1 %32
    • Use a 5/32 inch hex wrench to loosen the two set screws on the clutch drum.
  5. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: passo 5, imagem 1 %32 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: passo 5, imagem 2 %32
    • Slide the clutch drum straight off of the clutch rotor assembly.
  6. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: passo 6, imagem 1 %32 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: passo 6, imagem 2 %32 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: passo 6, imagem 3 %32
    • Use a flathead screwdriver or small pry bar to pry the clutch drum off of the flexible shaft.
    • Slide the clutch drum off of the flexible shaft and remove it.
    • During reassembly, apply anti-seize lubricant to the interface between the clutch drum and flexible shaft.
    • The clutch drum can be replaced as part of the clutch assembly replacement.
    • The replacement clutch drum should come with a new pilot bearing installed. If it doesn't, you may need to install a new pilot bearing.
  7. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Remove the clutch rotor assembly: passo 7, imagem 1 %32 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Remove the clutch rotor assembly: passo 7, imagem 2 %32
    • Use a long-handle 5/32 inch hex wrench to loosen the two set screws on the clutch rotor assembly.
    • The first photo shows the set screws on the replacement part for reference. Loosen the screws on the installed part, not the replacement part.
    • The screws are positioned behind the clutch rotor and won't be easy to access. Use a long-handle hex wrench as shown in the second photo.
  8. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: passo 8, imagem 1 %32 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: passo 8, imagem 2 %32
    • Slide the clutch rotor assembly off of the engine drive shaft.
    • The clutch rotor assembly can be replaced as part of the clutch assembly replacement.
    • During reassembly, make sure the clutch rotor assembly key is inserted correctly into its slot before reassembly.
    • During reassembly, apply anti-seize lubricant to the interface between the clutch rotor and engine drive shaft.
Conclusão
Adam O'Camb
Membro desde: 04/11/15
196.326 Reputação
Autoria de 416 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 709
