Introdução
Use this guide to replace the clutch assembly in a Little Beaver Augers MDL5HD 2017.
The auger bit is removed in this guide. While not necessary, removing it will make the repair easier.
O que você precisa
Pull the spark plug connector straight off of the spark plug.
Use a 5/16 inch socket to remove the two nuts securing the clutch bracket clamp.
Use a 5/32 inch hex wrench to loosen the two set screws on the clutch drum.
Use a long-handle 5/32 inch hex wrench to loosen the two set screws on the clutch rotor assembly.
