Ir para o conteúdo principal
Lite-On iHAS324 Disc Tray Belt Replacement
O que você precisa
  1. Lite-On iHAS324 Disc Tray Belt Replacement, Chassis: passo 1, imagem 1 %32 Lite-On iHAS324 Disc Tray Belt Replacement, Chassis: passo 1, imagem 2 %32
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Disc Tray Belt Replacement: passo 2, imagem 1 %32 Lite-On iHAS324 Disc Tray Belt Replacement: passo 2, imagem 2 %32 Lite-On iHAS324 Disc Tray Belt Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Disc Tray Belt Replacement: passo 3, imagem 1 %32
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Disc Tray Belt Replacement: passo 4, imagem 1 %32
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Disc Tray Belt Replacement: passo 5, imagem 1 %32
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Disc Tray Belt Replacement: passo 6, imagem 1 %32
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
  7. Lite-On iHAS324 Disc Tray Belt Replacement, Disc Tray: passo 7, imagem 1 %32 Lite-On iHAS324 Disc Tray Belt Replacement, Disc Tray: passo 7, imagem 2 %32
    • Push the left tab in and slide the tray out on the left side.
    • Pull the gray plastic casing on the right side away from the tray.
    • Slide the right side of the tray out.
  8. Lite-On iHAS324 Disc Tray Belt Replacement, Disc Tray Belt: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Take tweezers and remove the black tray belt from the gears carefully.
Conclusão
3 outras pessoas executaram este guia.
Kayla Culpepper
Membro desde: 03/22/15
702 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 5-9, Williams Spring 2015 Membro de Baylor, Team 5-9, Williams Spring 2015
BU-WILLIAMS-S15S5G9
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 30
Duração total: 1,677
