Introdução
If your drive is having problems opening, the drive belt may have broken or fallen out of the track and you will need to replace it.
O que você precisa
Insert an open paper clip into the small hole on the left side of the faceplate.
After the tray opens, extend it fully.
Ferramenta utilizada neste passo:Tweezers$4.99
Extend the tray so that the belt is accessible.
Remove the old belt using tweezers.
6 outras pessoas executaram este guia.
1Comentário do guia
In case anyone is interested, I used a 11/16” OD x 9/16” I.D. x 1/16” wall, for this exact drive (was a tight fit) and seems to work perfect.
I was so tired of replacing rubber bands every few months!
And yes this is an “O-ring” it should be less than a buck five eighty at your local big box hardware store.
