Ir para o conteúdo principal
Lite-On LightScribe SHM-165H6S Disc Tray Replacement
O que você precisa
  1. Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Chassis: passo 1, imagem 1 %32 Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Chassis: passo 1, imagem 2 %32
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 2, imagem 1 %32 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 2, imagem 2 %32 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 2, imagem 3 %32
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 3, imagem 1 %32
    • Pull the faceplate away from the main chassis.
  4. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 4, imagem 1 %32
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 5, imagem 1 %32 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 5, imagem 2 %32
    • Lift the top and bottom chassis straight up in order to remove them.
  6. Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Disc Tray: passo 6, imagem 1 %32 Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Disc Tray: passo 6, imagem 2 %32 Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Disc Tray: passo 6, imagem 3 %32
    • Extend the tray fully.
    • Push the tab on the right side to the left.
    • Push the tab on the left side to the left.
    • Remove the tray carefully.
  7. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 7, imagem 1 %32 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 7, imagem 2 %32 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 7, imagem 3 %32
    • Guide the replacement tray under the beige tabs.
    • Make sure the grey piece is slid to the right, so the grey nob is under the right-hand groove of the tray.
    • Check to see that the tray extends and closes smoothly.
Conclusão
Uma outra pessoa concluiu este guia.
James Biggs
Membro desde: 10/12/11
614 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-5, Regan Fall 2011 Membro de Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
Membros da 2
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 4,270
