Ir para o conteúdo principal
Introdução
Remove the top cover of the optical drive to access the internals and replace any malfunctioning components.
Peças
Nenhum componente especificado.
  1. Insert an open paper clip into the small hole on the left side of the faceplate. After the tray opens, extend it fully.
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Pull the faceplate away from the main chassis.
    • Pull the faceplate away from the main chassis.
  4. Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lift the top and bottom chassis straight up in order to remove them. Lift the top and bottom chassis straight up in order to remove them.
    • Lift the top and bottom chassis straight up in order to remove them.
Conclusão
2 outras pessoas concluíram este guia.
James Biggs
Membro desde: 12/10/2011
596 Reputação
3 Guias de autoria
Equipe
Cal Poly, Team 6-5, Regan Fall 2011 Membro de Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 Membros
3 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 2,579
