Ir para o conteúdo principal
Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement
O que você precisa
  1. Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: passo 1, imagem 1 %32
    • Turn the device over so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement: passo 2, imagem 1 %32
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement: passo 3, imagem 1 %32 Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement: passo 3, imagem 2 %32
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement, Motor: passo 4, imagem 1 %32 Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement, Motor: passo 4, imagem 2 %32
    • Use a pair of tweezers to crush the sides of the wirenuts.
    • The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Pull all of the wires out of the wirenuts.
  5. Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement: passo 5, imagem 1 %32 Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement: passo 5, imagem 2 %32
    • Separate the wires that belong to the motor.
    • The wires should be small and black.
    • Remove the motor.
Conclusão
To reassemble your device, follow these instructions in reverse order, starting from step five.
Courtney Elliott
Membro desde: 01/14/14
375 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 17-3, Forte Winter 2014 Membro de Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
Membros da 5
Autoria de 7 guias
2 comentários
Where can you find a replacement motor?
bellyjb - Responder
I can't find one either!!!!
Dallin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 2,583
