Introdução
If you just can't find out what is wrong with your disco ball, you will probably need to open it to troubleshoot it. This guide will walk you through the steps to do that.
Peças
Não são necessárias peças.
  1. Turn the device over so that the base is on top.
    • Turn the device over so that the base is on top.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Peel off the piece of metal that is glued to hold the two halves of the base together.
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  4. Unscrew the four 10mm Phillips head screws on the bottom of the device. Once the base is removed, the device should look as shown on the picture.
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
Conclusão
Nick Kaprielian
495 reputação
4 Guides authored
Equipe
Cal Poly, Team 17-3, Forte Winter 2014 Membro de Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Membros
7 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 364
