Ir para o conteúdo principal
Linksys WRT54GS v2 Motherboard Replacement
O que você precisa
  1. Linksys WRT54GS v2 Motherboard Replacement, Front Case: passo 1, imagem 1 %32
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Motherboard Replacement: passo 3, imagem 1 %32
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Motherboard Replacement: passo 4, imagem 1 %32
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Motherboard Replacement: passo 6, imagem 1 %32
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
Conclusão
Allian Roman
Membro desde: 10/12/11
276 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 3-4, Regan Fall 2011 Membro de Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 2,785
