Introdução
In this guide you will remove the router's front case and begin to have access to the router's internal components.
O que você precisa
Remove the rubber inserts inside the the two purple feet located on the router's front case.
This may be a challenge, so try the following two methods:
Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
Uma outra pessoa concluiu este guia.
