Ir para o conteúdo principal
Linksys WAP54g Antennas Replacement
  1. Linksys WAP54g Antennas Replacement, Antennas: passo 1, imagem 1 %32 Linksys WAP54g Antennas Replacement, Antennas: passo 1, imagem 2 %32
    • Make sure the antennas are in a straight position, not bent, to remove the black casing.
    • Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
  2. Linksys WAP54g Antennas Replacement: passo 2, imagem 1 %32
    • Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
  3. Linksys WAP54g Antennas Replacement: passo 3, imagem 1 %32
    • Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
  4. Linksys WAP54g Antennas Replacement: passo 4, imagem 1 %32
    • Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
  5. Linksys WAP54g Antennas Replacement: passo 5, imagem 1 %32
    • Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
    • Repeat these steps for other antenna.
Conclusão
After the repairs are made the device should working.
Derek Myers
Membro desde: 10/04/11
288 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 21-21, Maness Fall 2011 Membro de Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 2,598
