Introdução
For optimal performance, the middle antenna needs to be pointed straight up and the side antennas should be angled outwards at +/- 30 degrees.
If the antennas are not staying in place, it could affect the performance of the router, and you need to be replace them.
O que você precisa
Detach the wires from the motherboard.
Flip the motherboard and repeat the process.
4 outras pessoas executaram este guia.
