Ir para o conteúdo principal
Likebook Muses Rear Cover Replacement
O que você precisa
  1. Likebook Muses Rear Cover Replacement, Power off: passo 1, imagem 1 %32
    • Power off the tablet by holding down the power button (on the bottom) and tapping "Power off" on screen, then wait 10-15 seconds for the underlying Android system to shut down.
  2. Likebook Muses Rear Cover Replacement, Rear Cover: passo 2, imagem 1 %32
    • Unscrew the two Torx T2 screws surrounding the USB port.
    • Image needed: showing just the bottom in order to highlight screws in blue
  3. Likebook Muses Rear Cover Replacement: passo 3, imagem 1 %32 Likebook Muses Rear Cover Replacement: passo 3, imagem 2 %32 Likebook Muses Rear Cover Replacement: passo 3, imagem 3 %32
    • Use the opening tool to pry at the lip in between the bezel and rear cover,
    • then slide in your opening pick with the flat end,
    • and slide it around to undo these clips.
  4. Likebook Muses Rear Cover Replacement: passo 4, imagem 1 %32 Likebook Muses Rear Cover Replacement: passo 4, imagem 2 %32 Likebook Muses Rear Cover Replacement: passo 4, imagem 3 %32
    • (Note to self: Try opening the side using opening tools)
    • After releasing the clips, lift the front bezel out.
    • The extension piece for the power button can fall out. Don't lose this!
  5. Likebook Muses Rear Cover Replacement: passo 5, imagem 1 %32
    • The rear cover has been removed.
Conclusão
Uma outra pessoa concluiu este guia.
Kevin Bhasi
Membro desde: 12/26/14
1.262 Reputação
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 126
