Ir para o conteúdo principal
LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming
O que você precisa
  1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: passo 1, imagem 1 %32 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: passo 1, imagem 2 %32 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: passo 1, imagem 3 %32
    • Use a spudger to gently pry open the remote case to access the battery compartment.
    Pergunte ao FixBot
  2. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 2, imagem 1 %32 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 2, imagem 2 %32 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 2, imagem 3 %32
    • Carefully remove the old battery using a spudger.
    Pergunte ao FixBot
  3. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 3, imagem 1 %32 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 3, imagem 2 %32
    • Place the new battery into the compartment securely, noting the orientation of its positive and negative sides.
    Pergunte ao FixBot
  4. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 4, imagem 1 %32 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 4, imagem 2 %32 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 4, imagem 3 %32
    • Turn the remote upside down and push the cover gently until you hear a click, ensuring it is securely closed.
    • Align the cover to the remote buttons.
    Pergunte ao FixBot
  5. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 5, imagem 1 %32 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 5, imagem 2 %32
    • Locate the garage door system on top of the garage and open it.
    Pergunte ao FixBot
  6. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 6, imagem 1 %32 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 6, imagem 2 %32 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 6, imagem 3 %32
    • Locate the learn button.
    • Press and release the receiver learn button.
    • Within 30 seconds, press and hold remote button.
    • When the opener light flashes, release the remote button which means the programming was successful.
    Pergunte ao FixBot
  7. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 7, imagem 1 %32
    • Press the remote button to ensure it opens and closes the garage door as expected.
    • If the remote does not work, repeat Step 6.
    Pergunte ao FixBot
  8. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: passo 8, imagem 1 %32
    • In case the remote fails and the garage door is closed, use the side-mounted wall remote for emergency access.
    • Press the green light.
    Pergunte ao FixBot
Linha de Chegada
Luay Ghabayin
Membro desde: 07/02/24
157 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 33
Últimos 30 dias: 122
Ao todo: 2,110
