Introdução
This guide will show you the steps to replace the battery of the LifeTrak C410. Replacement battery can be found here.
O que você precisa
Grasp the body of the watch between your thumb and your index finger.
Slide the band through its clasp.
Remove the four 5.24 mm screws using a Phillips #0 screwdriver.
Remove the back panel.
