Ir para o conteúdo principal
LifePrint 2x3 Motor-Feeder Replacement
  1. LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: passo 1, imagem 1 %32 LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: passo 1, imagem 2 %32 LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: passo 1, imagem 3 %32
    • Make sure the top of the Lifeprint is facing upwards displaying the Lifeprint logo.
    • Slide open the top cover and remove the top lid.
  2. LifePrint 2x3 Motor-Feeder Replacement: passo 2, imagem 1 %32 LifePrint 2x3 Motor-Feeder Replacement: passo 2, imagem 2 %32 LifePrint 2x3 Motor-Feeder Replacement: passo 2, imagem 3 %32
    • Remove the six screws on the outer sides of the device with the Phillips #00 screwdriver.
    • The motor is highlighted in orange.
  3. LifePrint 2x3 Motor-Feeder Replacement: passo 3, imagem 1 %32 LifePrint 2x3 Motor-Feeder Replacement: passo 3, imagem 2 %32
    • After removing the six screws, gently flip the device over so the bottom cover is facing you.
    • Remove the bottom cover by using the opening pick.
  4. LifePrint 2x3 Motor-Feeder Replacement: passo 4, imagem 1 %32 LifePrint 2x3 Motor-Feeder Replacement: passo 4, imagem 2 %32 LifePrint 2x3 Motor-Feeder Replacement: passo 4, imagem 3 %32
    • Remove the four screws using the Phillips #00 screwdriver to access the motor and sensor (highlighted in orange).
  5. LifePrint 2x3 Motor-Feeder Replacement: passo 5, imagem 1 %32 LifePrint 2x3 Motor-Feeder Replacement: passo 5, imagem 2 %32 LifePrint 2x3 Motor-Feeder Replacement: passo 5, imagem 3 %32
    • Remove the component holding the motor and feeder.
    • Using a spudger remove the top piece of the component to get to the motor and feeder.
    • Remove the motor and feeder assembly from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 273
