Ir para o conteúdo principal
Lezyne Micro Drive Battery Replacement
O que você precisa
  1. Lezyne Micro Drive Battery Replacement, Battery: passo 1, imagem 1 %32
    • Mount the light in between a 11mm socket and 22 socket like so in a vice.
  2. Lezyne Micro Drive Battery Replacement: passo 2, imagem 1 %32
    • Slowly clamp, the clear light cover will push in. There is quite a lot of resistance.
  3. Lezyne Micro Drive Battery Replacement: passo 3, imagem 1 %32
    • Keep on going until the resistance fades. The light cover will be depressed as shown. and the electronics will just fall out.
  4. Lezyne Micro Drive Battery Replacement: passo 4, imagem 1 %32 Lezyne Micro Drive Battery Replacement: passo 4, imagem 2 %32 Lezyne Micro Drive Battery Replacement: passo 4, imagem 3 %32
    • You can see where the electronics slides into.
    • You can see how it is held in with friction from the raised plastic bevel. If you wish to make it easier to disassemble, file the friction bevel down. Don't file down the keying semi circular bevel.
    • The last picture shows the plastic filed down.
Conclusão
To reassemble your device, just put it back together.
11 outras pessoas executaram este guia.
graham
Membro desde: 08/21/13
350 Reputação
Autoria de 1 guia
30 comentários
Thanks just repaired my Lezyne Macro Drive front light. Light would flicker, just needed to re-solder the top left resistor shown in step 4.
richard taylor - Responder
Thanks to your instruction I was able to fix my lezyne micro drive which had denied to work after short-circuiting the charging leads by accident. Just cut the battery and reconnected it - light was working again! Worked out nicely!
Thanks!
mongo - Responder
Is it a 123 cell it takes? I will do this when I visit my father as he has a large vice. Thanks for the guide!
Aerotec - Responder
Yes a "CR-123" cell 3V lithium ion
graham -
you can just push the electronics and battery out with your thumb. Usually the issue with these batteries is the battery contact gets slightly corroded. Clean it with battery cleaner, and twist the battery a bit for a new and clean connection.
scotdferguson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 117
Duração total: 34,311
