Ir para o conteúdo principal
Lexmark Intuition S505 Ink Cartridges Replacement
  1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: passo 1, imagem 1 %32 Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: passo 1, imagem 2 %32
    • Lift the scanning unit, exposing the print head.
  2. Lexmark Intuition S505 Ink Cartridges Replacement: passo 2, imagem 1 %32
    • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
  3. Lexmark Intuition S505 Ink Cartridges Replacement: passo 3, imagem 1 %32
    • Lift the frame to expose the ink cartridges.
  4. Lexmark Intuition S505 Ink Cartridges Replacement: passo 4, imagem 1 %32
    • Push the button located above the designated ink cartridge until it pops out.
  5. Lexmark Intuition S505 Ink Cartridges Replacement: passo 5, imagem 1 %32
    • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
  6. Lexmark Intuition S505 Ink Cartridges Replacement: passo 6, imagem 1 %32 Lexmark Intuition S505 Ink Cartridges Replacement: passo 6, imagem 2 %32
    • Close the scanner unit.
Conclusão
Once your ink cartridges are in place, your printer should now print high-quality documents.
Omar
Membro desde: 01/23/13
111 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-38, Regan Winter 2013 Membro de Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
Membros da 4
Autoria de 8 guias
Um comentário
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 3,239
