Introdução
This guide will show you how to replace your speaker which will require a plastic spudger and soldering iron.
O que você precisa
Insert the blue plastic opening tool where the case has a seam. Move side to side until you hear a clip pop. Move around the edge of the case until all clips are separated. The clips are 1.5 in. apart within the case.
Quase terminado!
Conclusão
