Ir para o conteúdo principal
Les Paul Wireless Guitar Peripheral Neck Connection Replacement
O que você precisa
  1. Les Paul Wireless Guitar Peripheral Neck Connection Replacement, Les Paul Wireless Guitar Body Teardown: passo 1, imagem 1 %32
    • Remove batteries
  2. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 2, imagem 1 %32 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 2, imagem 2 %32
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 3, imagem 1 %32 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 3, imagem 2 %32 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 3, imagem 3 %32
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Peripheral Neck Connection Replacement, Neck Connection: passo 4, imagem 1 %32 Les Paul Wireless Guitar Peripheral Neck Connection Replacement, Neck Connection: passo 4, imagem 2 %32
    • Remove the 10 screws (each are 1 cm long) on the back of the neck using a T-10 Torx security screwdriver.
    • Remove the back of the neck.
  5. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 5, imagem 1 %32 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 5, imagem 2 %32
    • First check to see if the button motherboard is not damaged.
    • Next, make sure the wire is not damaged.
    • Then make sure that the connection motherboard is also not damaged.
    • If any of these parts are damaged, then it will need to be replaced.
  6. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 6, imagem 1 %32
    • Check to see if the neck connection chip is not damaged inside of the guitar.
    • Make sure that all 8 prongs of the chip are not damaged or broken.
    • If the neck chip is damaged then it will need to be replaced.
  7. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 7, imagem 1 %32 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 7, imagem 2 %32 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 7, imagem 3 %32
    • The lock mechanism may be another reason for trouble in your neck connection.
    • Use the guitar tear down to open the guitar to this point.
    • Start by unscrewing the two screws holding down the main connection parts. The first screw is 1 cm and the second screw is 0.8 cm.
  8. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 8, imagem 1 %32
    • Take the spring off the main connection mechanism. It should come off pretty easily.
    • If this spring is broken or snapped, then it will need to be replaced.
  9. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 9, imagem 1 %32 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: passo 9, imagem 2 %32
    • Pull out the main connection mechanism.
    • Make sure that it is not broken or it will need to be replaced.
    • This can be put back together by inserting the mechanism again, attaching the spring and screwing the two screws back in place.
Conclusão
Chris
Membro desde: 10/18/13
881 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 77
Duração total: 11,903
