Ir para o conteúdo principal
Les Paul Wireless Guitar Battery Pack Replacement
O que você precisa
  1. Les Paul Wireless Guitar Battery Pack Replacement, Les Paul Wireless Guitar Body Teardown: passo 1, imagem 1 %32
    • Remove batteries
  2. Les Paul Wireless Guitar Battery Pack Replacement: passo 2, imagem 1 %32 Les Paul Wireless Guitar Battery Pack Replacement: passo 2, imagem 2 %32
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Battery Pack Replacement: passo 3, imagem 1 %32 Les Paul Wireless Guitar Battery Pack Replacement: passo 3, imagem 2 %32 Les Paul Wireless Guitar Battery Pack Replacement: passo 3, imagem 3 %32
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: passo 4, imagem 1 %32 Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: passo 4, imagem 2 %32
    • Gently move the capacitor around until it breaks off
  5. Les Paul Wireless Guitar Battery Pack Replacement: passo 5, imagem 1 %32
    • Solder on the new capacitor.
Conclusão
3 outras pessoas executaram este guia.
Chris
Membro desde: 10/18/13
881 Reputação
Autoria de 6 guias
2 comentários
Mine is: 2200uF 10V
Thijs van Ulden -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 148
Duração total: 12,702
