Ir para o conteúdo principal
Lenovo bluetooth mouse N6901A disassembly
O que você precisa
  1. Lenovo bluetooth mouse N6901A disassembly, Mouse: passo 1, imagem 1 %32
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. Lenovo bluetooth mouse N6901A disassembly: passo 2, imagem 1 %32 Lenovo bluetooth mouse N6901A disassembly: passo 2, imagem 2 %32
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Lenovo bluetooth mouse N6901A disassembly: passo 3, imagem 1 %32 Lenovo bluetooth mouse N6901A disassembly: passo 3, imagem 2 %32
    • At this point, you have separated the mouse cover
  4. Lenovo bluetooth mouse N6901A disassembly: passo 4, imagem 1 %32
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  5. Lenovo bluetooth mouse N6901A disassembly: passo 5, imagem 1 %32 Lenovo bluetooth mouse N6901A disassembly: passo 5, imagem 2 %32
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
Conclusão
Shinn Chyang Chen
Membro desde: 09/14/11
2.953 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 31
Duração total: 5,531
