Ir para o conteúdo principal
Lenovo Z70-80 Motherboard Replacement
O que você precisa
  1. Lenovo Z70-80 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Lenovo Z70-80 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Use your fingers two push both latches away from each other to release the battery.
    • Pull the battery out.
  2. Lenovo Z70-80 Motherboard Replacement, Back Panel: passo 2, imagem 1 %32 Lenovo Z70-80 Motherboard Replacement, Back Panel: passo 2, imagem 2 %32 Lenovo Z70-80 Motherboard Replacement, Back Panel: passo 2, imagem 3 %32
    • Remove the two Phillips #0 screws from the bottom panel.
    • Slide the panel down slightly, and then lift to pull it off.
  3. Lenovo Z70-80 Motherboard Replacement, Optical Drive: passo 3, imagem 1 %32 Lenovo Z70-80 Motherboard Replacement, Optical Drive: passo 3, imagem 2 %32 Lenovo Z70-80 Motherboard Replacement, Optical Drive: passo 3, imagem 3 %32
    • Remove the single 3mm Phillips #0 screw from the optical drive.
    • Pull the optical drive out of the side.
  4. Lenovo Z70-80 Motherboard Replacement, Electric Fan: passo 4, imagem 1 %32 Lenovo Z70-80 Motherboard Replacement, Electric Fan: passo 4, imagem 2 %32 Lenovo Z70-80 Motherboard Replacement, Electric Fan: passo 4, imagem 3 %32
    • Remove the three 6mm Phillips #0 screws from the fan.
    • Disconnect the fan from the motherboard by pulling up on the plug.
  5. Lenovo Z70-80 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove all the 17 7mm Phillips #0 screws.
    • A sticker covers this screw. Remove this sticker to remove the screw.
    • Remove the back cover.
  6. Lenovo Z70-80 Motherboard Replacement: passo 6, imagem 1 %32 Lenovo Z70-80 Motherboard Replacement: passo 6, imagem 2 %32 Lenovo Z70-80 Motherboard Replacement: passo 6, imagem 3 %32
    • Pry the edges of the keyboard upwards using a spudger.
    • A cable with a ZIF connector is attached to the bottom of the keyboard. Flip the small black tab on the connector for safe removal.
    • Remove the five 3mm Phillips #0 screws.
  7. Lenovo Z70-80 Motherboard Replacement: passo 7, imagem 1 %32 Lenovo Z70-80 Motherboard Replacement: passo 7, imagem 2 %32 Lenovo Z70-80 Motherboard Replacement: passo 7, imagem 3 %32
    • Remove all the ribbon cables and connectors from the front and back of the laptop.
    • Remember to flip the small black tabs on ZIF connectors for safe removal.
  8. Lenovo Z70-80 Motherboard Replacement: passo 8, imagem 1 %32 Lenovo Z70-80 Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the 3mm screw and carefully pull out the cables from the hooks holding them in place.
  9. Lenovo Z70-80 Motherboard Replacement: passo 9, imagem 1 %32 Lenovo Z70-80 Motherboard Replacement: passo 9, imagem 2 %32
    • Use a spudger at the edges of the laptop cover to carefully pry upwards, removing the cover.
  10. Lenovo Z70-80 Motherboard Replacement: passo 10, imagem 1 %32 Lenovo Z70-80 Motherboard Replacement: passo 10, imagem 2 %32 Lenovo Z70-80 Motherboard Replacement: passo 10, imagem 3 %32
    • Unplug the two black cables from the motherboard.
    • Remove the three 3mm screws from the motherboard.
    • Remove the motherboard.
    • Pick up the motherboard carefully by the edges.
Conclusão
3 outras pessoas executaram este guia.
Eduardo Delgado
Membro desde: 01/24/18
412 Reputação
Autoria de 4 guias
Equipe
Gateway, Team S1-G4, Johnson Spring 2018 Membro de Gateway, Team S1-G4, Johnson Spring 2018
GCC-JOHNSON-S18S1G4
Membros da 2
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 32
Duração total: 4,006
