Introdução
This guide will explain how to remove the back panel on a Lenovo Z70-80 laptop.
O que você precisa
Use your fingers two push both latches away from each other to release the battery.
Pull the battery out.
Remove the two Phillips #0 screws from the bottom panel.
Slide the panel down slightly, and then lift to pull it off.
Uma outra pessoa concluiu este guia.
