Ir para o conteúdo principal
Lenovo Yoga Tablet 2 830-F Motherboard Replacement
O que você precisa
  1. Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw on the back fo the device with a Phillips #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: passo 2, imagem 1 %32 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the six 3mm screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Remove ZIF connectors connecting the boards to the electrical components.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: passo 3, imagem 1 %32 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: passo 3, imagem 2 %32
    • Replace the motherboard with the new motherboard.
    • Be careful not to damage the ribbon cables when reassembling the device.
Conclusão
Charles Rhode
Membro desde: 09/28/17
594 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S2-G4, Nance Fall 2017 Membro de USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 2,004
