Ir para o conteúdo principal
Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement
O que você precisa
  1. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement, Headphone Jack: passo 1, imagem 1 %32 Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement, Headphone Jack: passo 1, imagem 2 %32
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw with a Phillips #00 bit.
    • Using the blue opening tool or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement: passo 2, imagem 1 %32
    • Remove the three 2mm screws on the back of the left speaker module with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement: passo 3, imagem 1 %32
    • Gently remove the left speaker module.
    • Replace the old left speaker module with the new left speaker module.
    • Be careful not to damage the ribbon cables on the new left speaker module while reassembling the device.
Conclusão
3 outras pessoas executaram este guia.
Charles Rhode
Membro desde: 09/28/17
594 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S2-G4, Nance Fall 2017 Membro de USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Duração total: 1,930
