Ir para o conteúdo principal
Lenovo Yoga Tablet 2 830-F Antenna Replacement
O que você precisa
  1. Lenovo Yoga Tablet 2 830-F Antenna  Replacement, Wifi Antenna: passo 1, imagem 1 %32 Lenovo Yoga Tablet 2 830-F Antenna  Replacement, Wifi Antenna: passo 1, imagem 2 %32
    • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Antenna  Replacement: passo 2, imagem 1 %32 Lenovo Yoga Tablet 2 830-F Antenna  Replacement: passo 2, imagem 2 %32 Lenovo Yoga Tablet 2 830-F Antenna  Replacement: passo 2, imagem 3 %32
    • Remove the six screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
    • Remove the three screws on the back of the secondary board with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components.
    • Remove the ZIF connectors connecting the boards to the other electrical components.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Antenna  Replacement: passo 3, imagem 1 %32
    • Disconnect the antenna module from the motherboard.
Conclusão
Mario Gjyli
Membro desde: 09/28/17
449 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S2-G4, Nance Fall 2017 Membro de USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 946
