Introdução
If you need to replace your faulty battery use this guide. The battery is located inside the kickstand, thus you will need to know how to remove the back facing camera and the headphone jack.
O que você precisa
Use the metal spudger to push out the lock of the battery compartment by putting the metal spudger between the kickstand and the plastic and applying a force upwards.
4 outras pessoas executaram este guia.
Um comentário
the battery removal is shown to be difficult
here shows the right way
