Ir para o conteúdo principal
Lenovo Yoga Tab 3 8 Kickstand Lock Replacement
O que você precisa
  1. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Back Cover: passo 1, imagem 3 %32
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: passo 2, imagem 1 %32
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: passo 3, imagem 1 %32 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: passo 3, imagem 2 %32 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: passo 3, imagem 3 %32
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
  4. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement, Kickstand Lock: passo 4, imagem 1 %32
    • Locate the four 2mm screws that secure the lock and remove them with a PH00 screwdriver.
  5. Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: passo 5, imagem 1 %32 Lenovo Yoga Tab 3 8 Kickstand Lock Replacement: passo 5, imagem 2 %32
    • Pry the lock up with a metal spudger. There is adhesive holding the mechanism down. Carefully separate it using even pressure.
Conclusão
Nicklaus Krems
Membro desde: 09/25/17
1.049 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team S16-G2, Eyestone Fall 2017 Membro de USF Tampa, Team S16-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S16G2
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 893
