Ir para o conteúdo principal
Lenovo Yoga Tab 3 8 Hinge Replacement
O que você precisa
  1. Lenovo Yoga Tab 3 8 Hinge Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo Yoga Tab 3 8 Hinge Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo Yoga Tab 3 8 Hinge Replacement, Back Cover: passo 1, imagem 3 %32
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Hinge Replacement: passo 2, imagem 1 %32
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Hinge Replacement: passo 3, imagem 1 %32 Lenovo Yoga Tab 3 8 Hinge Replacement: passo 3, imagem 2 %32 Lenovo Yoga Tab 3 8 Hinge Replacement: passo 3, imagem 3 %32
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
  4. Lenovo Yoga Tab 3 8 Hinge Replacement, Hinge: passo 4, imagem 1 %32 Lenovo Yoga Tab 3 8 Hinge Replacement, Hinge: passo 4, imagem 2 %32 Lenovo Yoga Tab 3 8 Hinge Replacement, Hinge: passo 4, imagem 3 %32
    • With the tablet oriented screen side down and hinge opposite of you, locate the black plastic piece on the top right.
    • Remove the upper 4mm and lower 3mm screws with a PH00 screwdriver.
  5. Lenovo Yoga Tab 3 8 Hinge Replacement: passo 5, imagem 1 %32 Lenovo Yoga Tab 3 8 Hinge Replacement: passo 5, imagem 2 %32
    • Position the kickstand to an almost closed position. Carefully move the plastic block aside and pry the metal lock out with a metal spudger.
    • Be careful not to pull off the wires connecting the plastic block.
    • The lock may be difficult to remove so you may need to apply more pressure to release the lock.
  6. Lenovo Yoga Tab 3 8 Hinge Replacement: passo 6, imagem 1 %32 Lenovo Yoga Tab 3 8 Hinge Replacement: passo 6, imagem 2 %32 Lenovo Yoga Tab 3 8 Hinge Replacement: passo 6, imagem 3 %32
    • At the opposite end of the hinge, locate the silver metal bracket over the wires coming from the end of the hinge. Remove the two 3mm screws with a PH00 screwdriver. Lift the bracket off with your fingers.
    • Removing the bracket will expose two silver connectors at the ends of the wires coming from the end of the hinge. Use tweezers to carefully lift off the two silver connectors.
    • Locate the smaller metal wire bracket guiding the wires coming from the end of the hinge. Remove the single black 2mm screw with a PH00 screwdriver. Lift the bracket off with your fingers.
  7. Lenovo Yoga Tab 3 8 Hinge Replacement: passo 7, imagem 1 %32 Lenovo Yoga Tab 3 8 Hinge Replacement: passo 7, imagem 2 %32
    • Begin removing the entire hinge assembly by lifting it out, starting at the end where the lock is located. Carefully feed the wires through the hinge mount with your fingers as you pull the hinge assembly free.
Conclusão
Nicklaus Krems
Membro desde: 09/25/17
1.049 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team S16-G2, Eyestone Fall 2017 Membro de USF Tampa, Team S16-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S16G2
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 22
Duração total: 1,694
