Ir para o conteúdo principal
Lenovo Yoga Tab 3 10 Wifi Module Replacement
O que você precisa
  1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Back Cover: passo 1, imagem 1 %32
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 2, imagem 1 %32 Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 2, imagem 2 %32 Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 2, imagem 3 %32
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 3, imagem 1 %32 Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 3, imagem 2 %32 Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 3, imagem 3 %32
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: passo 4, imagem 1 %32 Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: passo 4, imagem 2 %32
    • Use the nylon spudger to gently lift the foil cover of the wifi model.
  5. Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 5, imagem 1 %32
    • Use tweezers to gently lift the gold tape located above the copper foil.
  6. Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 6, imagem 1 %32
    • Use the plastic spudger to disconnect the wifi module connector from the motherboard.
  7. Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 7, imagem 1 %32 Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 7, imagem 2 %32
    • Carefully lift the wifi module from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Phanudej
Membro desde: 02/20/17
1.184 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G2, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
Membros da 4
Autoria de 18 guias
Um comentário
where can i buy this type of module?
rebeca rackolavsci - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 31
Duração total: 3,466
