Ir para o conteúdo principal
Lenovo Yoga Tab 3 10 Camera Replacement
O que você precisa
  1. Lenovo Yoga Tab 3 10 Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Camera Replacement: passo 2, imagem 1 %32 Lenovo Yoga Tab 3 10 Camera Replacement: passo 2, imagem 2 %32 Lenovo Yoga Tab 3 10 Camera Replacement: passo 2, imagem 3 %32
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Camera Replacement: passo 3, imagem 1 %32 Lenovo Yoga Tab 3 10 Camera Replacement: passo 3, imagem 2 %32 Lenovo Yoga Tab 3 10 Camera Replacement: passo 3, imagem 3 %32
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Camera Replacement, Camera: passo 4, imagem 1 %32 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: passo 4, imagem 2 %32 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: passo 4, imagem 3 %32
    • Remove the 3 screws from the auxiliary port cover.
    • Use the spudger to gently push the auxiliary module out of the way.
    • Remove the detachable plastic latch located in front of the hinge.
  5. Lenovo Yoga Tab 3 10 Camera Replacement: passo 5, imagem 1 %32
    • Use a spudger to gently remove the hinge.
  6. Lenovo Yoga Tab 3 10 Camera Replacement: passo 6, imagem 1 %32
    • Carefully lift the kickstand away from the frame.
    • The battery is located inside of the kickstand. Ensure proper handling and care.
  7. Lenovo Yoga Tab 3 10 Camera Replacement: passo 7, imagem 1 %32 Lenovo Yoga Tab 3 10 Camera Replacement: passo 7, imagem 2 %32
    • Use the pointed end of a spudger to push in the camera's locking mechanism.
    • Upon releasing the camera lock lift the camera out and locate the three screws.
  8. Lenovo Yoga Tab 3 10 Camera Replacement: passo 8, imagem 1 %32 Lenovo Yoga Tab 3 10 Camera Replacement: passo 8, imagem 2 %32 Lenovo Yoga Tab 3 10 Camera Replacement: passo 8, imagem 3 %32
    • Use a J000 Philips screwdriver to remove the three screws.
    • Remove the camera cover that seals the camera case.
    • Remove the camera from the shell.
  9. Lenovo Yoga Tab 3 10 Camera Replacement: passo 9, imagem 1 %32
    • Separate the camera from its casing.
Conclusão
Phanudej
Membro desde: 02/20/17
1.187 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G2, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
Membros da 4
Autoria de 18 guias
Um comentário
Thanks for describing in details with bit and peaces very neatly and clearly. I fix the problem of my Lenovo Yoga 3 with help of this. Great job you have done.. keep it up… Sisira
Sisira Kumara - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 18
Duração total: 4,165
