Ir para o conteúdo principal
Lenovo Yoga Tab 3 10 Motherboard Replacement
O que você precisa
  1. Lenovo Yoga Tab 3  10 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 2, imagem 1 %32 Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 2, imagem 2 %32 Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 3, imagem 1 %32 Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 3, imagem 2 %32 Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 3, imagem 3 %32
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32 Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: passo 4, imagem 3 %32
    • Locate the screws in the motherboard the wire cover assembly and the speakers.
    • Use the J000 screwdriver to remove the screws on the motherboard, the wire cover, and the two speakers.
    • Disconnect the wifi connector on the motherboard.
  5. Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 5, imagem 1 %32 Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 5, imagem 2 %32
    • Use the spudger to lift the two speakers up from the small adhesive strip.
    • Place the spudger in the upper left corner of the motherboard and lift it to separate it from the adhesive strip under it.
    • Lift away the motherboard.
Conclusão
13 outras pessoas executaram este guia.
Phanudej
Membro desde: 02/20/17
1.184 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G2, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
Membros da 4
Autoria de 18 guias
Um comentário
Dear @phanudej ,
I liked your post. I’d have a remark and a question. I made a mistake during the maintanance; with wich I killed a part of the MOBO. So dear users my advice if you want to connect the LCD connector remove the battery before… I had never this issue but now happened. (the device was switched off)
Could you please take a photo of the powerstage of the LCD (I think it should be that) So between the inductor (100; 10uH coil) and an capacity there is a component I do not know what is it (it smoked away) I assume it is a diode…?! They are in the white rectangle near the LCD connector
Thanks in advance
Best regards
@harrincourt
Jozsef Szlatki - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 37
Duração total: 9,177
