Introdução
If you are having Wi-Fi problems and none of the solutions found on this troubleshooting page work, you may need to replace the physical Wi-Fi card in your Lenovo Yoga C930-13IKB. The only Wi-Fi card that is compatible with the Lenovo Yoga C930-13IKB is the Intel 9260 Wi-Fi card. Do not install a different Wi-Fi card.
Before buying a new card, check if all the wires are connected to the Wi-Fi card currently in your laptop. Poor physical connection to the motherboard or antenna will cause Wi-Fi problems.
O que você precisa
Flip the device over so that the underside is facing up.
Remove the six 3.5 mm T5 Torx screws.
Find the Wi-Fi card located on the right just above the battery. It is a green chip with a white label that says "Intel 9260" somewhere on it.
Gently pull or use the iFixit opening tool to detach the black and white wires from the card.
4 outras pessoas executaram este guia.
Um comentário
Brilliant! very clear instructions and it fixed my fault. I wonder if this is a relatively common fault. Windows unable to find WiFi adapter.
Thank you for your efforts
