Introdução
This guide can be used if the device’s back cover is damaged or replacement inside the device is needed. If you are unsure about what you need to replace underneath the back cover, visit this troubleshooting page.
Everything required to begin getting inside your device is here. For this guide, you will need a plastic opening tool and a T5 Torx screwdriver.
Make sure to turn off the device before taking it apart.
O que você precisa
Flip the device over so that the underside is facing up.
Remove the six 3.5 mm T5 Torx screws.
