Ir para o conteúdo principal
Lenovo Yoga C930-13IKB Back Cover Replacement
O que você precisa
  1. Lenovo Yoga C930-13IKB Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Back Cover Replacement: passo 2, imagem 1 %32 Lenovo Yoga C930-13IKB Back Cover Replacement: passo 2, imagem 2 %32
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Back Cover Replacement: passo 3, imagem 1 %32 Lenovo Yoga C930-13IKB Back Cover Replacement: passo 3, imagem 2 %32
    • Carefully lift the cover off with your hands.
Conclusão
Hanna Lazkani
Membro desde: 01/23/20
788 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S19-G5, White Winter 2020 Membro de Cal Poly, Team S19-G5, White Winter 2020
CPSU-WHITE-W20S19G5
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 52
Duração total: 2,663
